Εφαρμογή για καταχώρηση εκχυλίσεων
- spirosninja
- Όνομα: Σπύρος
- Μηχανή:: Lelit pl41
- Μύλος:: Eureka manual
- Οι καφέδες μου:: Speciality
Re: Εφαρμογή για καταχώρηση εκχυλίσεων
thank you for this great app! One suggestion... please do something about scale score. I Believe It's more useful to rate %
Graphefruit
Hi there!spirosninja έγραψε: ↑Τρί Απρ 27, 2021 6:29 pmthank you for this great app! One suggestion... please do something about scale score. I Believe It's more useful to rate %
Thanks for your suggestion and sorry for the late response.
In the next Version 5.4 there will be the option in settings to change rating for your own needs to a maximum of 100 "points".
So you can go to percentage rating 1-100 or just like 1-20 - as you need in the end
Greetings
Lars
Graphefruit
Hey
Thanks for the recommendation, this is already one thing in the backlog but actually not developed in the near future.
I hope you can understand this.
Lars
- spirosninja
- Όνομα: Σπύρος
Hi Lars! thanks very much for your response!Graphefruit έγραψε: ↑Τετ Μάιος 12, 2021 3:48 pmHi there!spirosninja έγραψε: ↑Τρί Απρ 27, 2021 6:29 pmthank you for this great app! One suggestion... please do something about scale score. I Believe It's more useful to rate %
Greetings
Lars
Graphefruit
Hello Coffee-Lovers,
the new Version 5.4 is live today!
What have been changed?
Roasting section:
Manage all of your green beans and roasters (can be activated in the settings menu)
Save all of your green beans and transfer them into roasted onces
Add your roaster and connect them with your different kind of roasted beans
Website:
Go live of our new website! -> https://beanconqueror.com
Support us:
You've always wanted to support Beanconqueror? We've added a new 'Buy me a coffee' connection
iOS - iCloud:
The first step into iCloud support was made. At the very first start all of your existing app data will be moved into the support iCloud directory.
You have to activate this option in the iCloud Settings first in order to save Beanconqueror on iCloud
Android/iOS - Automated file-export:
Automated Beanconqueror.json-File is saved for a maximum of 7 days, after that they will be automated deleted again
Android: Download/Beanconqueror_export/Beanconqueror_automatic_export_DAY.json
iOS: Files/Download/Beanconqueror_export/Beanconqueror_automatic_export_FILE.json
Settings:
Excel - Export all of your data to excel to work with it even further
Define your own image quality between 50% to 100% (default 100%)
Brew rating - Define how much stars/points you'd like to set for each brew. Minimum 5, maximum 100
New tracking:
We've changed to our open source service Matomo, which will be hosted on our own server
Removed Google Analytics / Firebase
Bug fixes:
Apple Healthkit - Settings were not saved
Sometimes brew rating stars weren't filled (Brew add/edit)
Edit via long tap, screen wasn't scrollable
Import of bigger files on iOS led to misconduct
Delete procedure of beans / preparations or mills were not consistent and lead to graphical issues
Wrong calculation of beverage quantity in statistics and list views
Share:
Share your brews and beans with all coffee lovers!
Other:
Clean ups
Layout changes
Extension of statistics
Startup check revised, added please wait window
Some label changes
Changed data access / order inside app to reduce problems
You'll find the app here:
Android: https://play.google.com/store/apps/deta ... queror.app
iOS: https://apps.apple.com/app/beanconqueror/id1445297158
Github: https://github.com/graphefruit/Beanconq ... tag/v5.4.0
Best regards
Lars
Roasting section:
Website:
Support us:
iOS - iCloud:
Settings:
New tracking:
Bug fixes:
Share:
Other:
Clean ups
Layout changes
Some label changes
Best regards
Lars
Graphefruit
the new Version 6.0 is live today!
Bluetooth scales
Support of the first bluetooth scale - Decent-Scale - Big thanks to Decent Espresso
Support of Acaia Lunar
Aroma cupping
Cup each brew with the different aromatics and flavors
Water section
Add your own water, activate this section in the settings
Support of more languages
Support for spanish - Big thanks to Frank!
Improvements
Support of long press '+' on brews
Added new brew parameters
Support of different currencies
Edit brew while in detail view
Choose multiple images at once
Support of brix to TDS conversion
If bean package is empty, you'll be asked if you want to archive the package on the last brew
Reset of roastdate supported
Support of detail views on beans, grinders and preparation methods
Added brew ratio (g/l)
iOS
Support of safe areas
Bug fixes
Apple Healthkit - Decaffeinated coffee was saved
Copy of beans led to misconduct
Added brew time to excel export
Small bug fixes
Others
Beans, grinders and preparation methods are now sorted alphabetic in dropdowns
You'll can find the app here:
iOS: https://apps.apple.com/us/app/beanconqu ... 1445297158
Github: https://github.com/graphefruit/Beanconq ... ag/v.6.0.0
Best regards
Lars
Bluetooth scales
Aroma cupping
Water section
Improvements
iOS
Bug fixes
Small bug fixes
Others
Best regards
Lars
- Earendil
- Όνομα: Dimitris
Hey Lars.
Thanks for these updates.
The app is great. I'm using it every day
Graphefruit
the new Version 6.1 is live today!
Before you start reading the patch notes:
Sadly there was an issue on Android with the Play Store.
If you didn't already read the popup screen, please make sure to go to the faq page: https://beanconqueror.com/faq
QR Codes
Scan your coffee bags! All coffee information are directly inserted from the roastery.
Bluetooth scales
Support of Acaia Pearl 2021 - Thanks to Micah and Mike
Support of Acaia Lunar 2021 - Thanks to Micah and Mike
Support of Acaia Pyxis - Thanks to Micah and Mike
Support of Hiroia Jimmy - Thanks to Silas
Support of Felicita Arc - Thanks to Herman
Care: Acaia Pearl lower 2021 is not supported right now
Weightinformation of bluetooth scale can now be used on the beans page
Weight changes are now visible without starting a brew via timer
Brew overview
Customize your visible brew parameters in the overview in general or for each preparation method
Preparation images are now visible in the listview
Brew graph
Rework of brew graph to a more smoother solution
Brew graph now can be maximized
Brew graph can now be zoomed in the brew-detail view aswell as exported
Average flow quantity is now displayed
Beans
Added fields: Buy date, FOB-Price, Purchasing price
Beans can now be favorited and filtered
If a bean gets archived, you can now rate the package aswell
Pressing '+' you can now choose to add or scan a new package
Long press '+' to directly add a new bean
Preparation methods
Preparation methods can now be repeated with all settings
More preparation methods are available - Thanks to Nicola
Selecting a preparation method also displays the image
Settings
Ratings can now be stepped (1, 0.75, 0.5, 0.25, 0.1)
Bluetooth scale - Define if the scale should be set to weight zero when starting a new brew, or starting the timer
Bluetooth scale - Define if you want to ignore anomalies or negative values - if yes, a live graph won't be possible
Choose now, if you want to see archived brews on the home page
Export also now exports the raw data of the saved bluetooth values
Improvements
Delete of preparation method tools now won't delete brews anymore
Preparation method tools now can be edited and archived
Bug fixes:
Recording or choosing images on Android works now on newer versions
Found more issues which could lead to a data loss
Small bug fixes
Others:
Updating to Ionic-Framework 6, therefore some small visual changes takes place
iOS: https://apps.apple.com/de/app/beanconqu ... 1445297158
Github: https://github.com/graphefruit/Beanconq ... ag/v.6.1.0
Best regards
Lars
QR Codes
Bluetooth scales
Brew overview
Brew graph
Beans
Preparation methods
Settings
Improvements
Bug fixes:
Small bug fixes
Others:
Best regards
Lars
Graphefruit
Hello together,
for all people suffering on data loss, and didn't had any automatic backup.
I could retrieve a way which is a bit "hacky" and you need some sort of technical knowledge, but its possible to over install an older version from Github where the app can access the old database.
Important thing: You never delete the Beanconqueror app!
More information can be found here:
https://github.com/graphefruit/Beanconq ... 1112638471
Let me know if I can help further
Lars
Lars
Graphefruit
the new Version 6.1.5 is live today!
A small patch
QR Codes
Reload beans which where scanned via qr-codes
Brew graph
Water flow is calculated now in realtime - Specially for espresso
Beans
Search beans now in selection
Bug fixes:
After taking a picture, the loading spinner didn't disappear
Smaller bugfixes
Github: https://github.com/graphefruit/Beanconq ... ag/v.6.1.5
Best regards
Lars
A small patch
QR Codes
Brew graph
Beans
Bug fixes:
Smaller bugfixes
Best regards
Lars
